Pitman arm
4x4 Related Discussion area for all makes and models
Pitman arm
Postby rick-rock on Feb 08 2010 08:11 pm
How often do these wear out. DoI buy them in an economical two pack ? :)
rick-rock
Re: Pitman arm
Postby FAM on Feb 08 2010 08:18 pm
Are you using a stock pitman arm or a drop pitman arm?  I haven't heard much about stock ones wearing out, but it seems like there was a bad batch of drop pitman arms from RE a while back that don't hold up well.  I helped Chuck replace his last fall.
KI6MLI
User avatar
FAM
Site Admin
Re: Pitman arm
Postby rick-rock on Feb 08 2010 08:45 pm
It's a stock arm with about 75 thousand miles on it. trails on it consist of barret lake ,strawberry and alot of sand.
rick-rock
Re: Pitman arm
Postby Bender on Feb 08 2010 08:52 pm
I'm no Jeep pitman arm expert, but what is there to wear out?  Assuming things are kept tight you should be fine.  If you're going to get a drop and are worried about breaking it, keep the old one as a spare to get you home.  That said, I didn't keep my TREs tight and rounded out the hole on mine nicely.   :oops:
Everything I say is fully substantiated by my own opinion.
User avatar
Bender
Re: Pitman arm
Postby RobD on Feb 08 2010 09:14 pm
I have never worn one out, but I have broke one in half and bent 2 others!
User avatar
RobD
Re: Pitman arm
Postby rick-rock on Feb 08 2010 09:31 pm
I
installed the Currie set-up  before the Berratt lake trip and tightened everything per the instructions. I didn't notice any slop at that time, but i did not check either.
So this last friday I went down at lunch time to have an alignment done. The guy said he could not because of the connection between the draglink and pitman. So i brought it home and checked myself and sure enough it was sloppy. I've ordered new parts to replace them ,no problem. So is this just a fluke or do these parts wear out with the many trails one travels.
rick-rock
Re: Pitman arm
Postby JohnDF on Feb 09 2010 06:19 am
I ran my original/stock pitman arm for 6 years until it bent this last Summer. I blame Strawberry.
The popcorn tastes like soap.
User avatar
JohnDF
Club Vice President
Re: Pitman arm
Postby RockinCrawler on Feb 09 2010 09:19 am
Mr brother told me years ago that the factory heats up the pitman arm before sliding it on the shaft and torqueing the nut.  So thats what they did at the dealer so they wouldnt work loose.
RockinCrawler
Re: Pitman arm
Postby lowrider on Feb 09 2010 09:20 am
:lol:  :lol:
JohnDF wrote:I ran my original/stock pitman arm for 6 years until it bent this last Summer. I blame Strawberry.
:lol:  :lol:  :lol: good one.  :lol:  :lol:  :lol:
lowrider
Club Prospect
Re: Pitman arm
Postby lj4x4 on Feb 09 2010 01:41 pm
I sheared off about half the splines an my brand new RE drop pitman arm. This was on Barrett and was the first trip with the new lift Kit.  It might not have been tight enough but I also think it was one of the "bad ones".  RE replaced it with out a problem.  I haven't had any problems with the new one.
I used antisieze and a large Impact gun to put it on.  I might never get it off but at least I won't strip the splines.
A day without sunshine is like night.
User avatar
lj4x4
Re: Pitman arm
Postby RobD on Feb 09 2010 05:31 pm
Carrying a spare pitman arm is never a bad idea. Most guys do here. They are small and easy to carry in your Jeep and a vital part of your steering and not easy to fix if they break half way across the Rubicon. Ask me how I know that  :mrgreen:
User avatar
RobD
Re: Pitman arm
Postby JohnDF on Feb 09 2010 05:34 pm
and they are mandatory for Hammers trips...ask Justin how he knows  :mrgreen:
User avatar
JohnDF
Club Vice President
Re: Pitman arm
Postby rick-rock on Feb 09 2010 07:25 pm
It's settled then , economical two pack.
rick-rock
Re: Pitman arm
Postby Justin on Feb 09 2010 08:45 pm
JohnDF wrote:and they are mandatory for Hammers trips...ask Justin how he knows  :mrgreen:
Yeah, John saved my rear on that run. I didn't have a spare but John happened to have the one I needed. 8)
I now carry a spare.
My offering to the mailbox at the top of the Sledgehammer Trail.
User avatar
Justin
Return to General 4x4 Discussion
Who is online
Users browsing this forum: No registered users and 1 guest
